tx bottom
Results 1 to 3 of 3
tx bottom
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Default tx bottom
    Please see my post in the jet boat section, i am confused on the where the "hook" is usually located.
    Mar 2010
    Clarksville, TN
    I'm sure others will chime in but it may not have a hook in it . I think the main thing is to make sure everything is straight and true and use a long (4 to 6ft) straight edge and check for any humps or dips .. But like I said it may be in good shape and just need a refinish
    Southwest corner AR
    I think you have the best info. in your other thread! I think hook will be nearest the transom and you may find dips in other areas around the intake! Flat is where it's at but you may find some hicups! Good luck and post up what you find!
    WT
    WFL Crew!!!
