Cfm ?
Results 1 to 6 of 6
Cfm ?
    Nov 2015
    Default Cfm ?
    Can having too big of runners/heads for the selected valvetrain actually be detrimental or is it only a waste of money?
    Tower Park Resort, Lodi, CA
    Quote Originally Posted by drc9805 View Post
    Too big for engine displacement at intended rpm range will be detrimental to low rpm torque and power.
    Nov 2015
    That's what I thought but I wanted to verify it here. Thanks!
    Tri-Cities, TN
    And it happens all the time. Companies in this industry feed off the consumers ego and catch phrase " Bigger is Better". When in reality it should be "Combination is King".
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    okie, lake Texoma
    I agree with what these guys are telling you, BUT--- need to know the intended application & cid. If this is a jetboat, you flash right through most of that midrange that many get hung up on and are building for one specific rpm, which is usually on up the scale- and with the common cid of engines today often being over 500 inch. Makes it a little harder to "over head" the engine.
    Car or v-drive accelerating through the gears, or a heavy cruiser- maybe an outdrive-- sure it becomes more of a problem then.
    Application. JMO though.
    H8-2-W8
    [email protected] first pass
    waterloo
    Amen brother.
    Wags
