18' Mr. Ed shovelnose hydro. (SANGER)
1 reading
18K views 19 replies 9 participants last post by  Rylanskulason
#1 ·
This little rocket was commisioned by Sanger to Ed Wills to come up with a small lightweight record setting hull. Here is what he came up with. It looks like a mini 20' Howatd shovelnose. The boats are wicked quick. There are only a few out there. Dante has the red orange one with a Ford motor and there is one on youtube that is stack injected and the guy posted a killer full throttle pass video on board. His boat is called After You I beleive. My boat is set up for a BBC. It is a sharp boat and is available with or without motor. $5000 without motor but will include BBC plates and pan and crank trigger ignution with 7AL box.
#2 ·
pics
This boat still looks great. I found this older photo of the boat on this forum and one of the previous owners posts on here frequently. The boat is in great shape and its a blast to drive. Just for fun we bolted a 434" small block in it with small shot of NO2 and went 117 mph with 7500rpm on the tach recall. Someone else claimed to run a 9.60 @ 112 mph 1/4 mile pass with a 396 BBC iron headed compression motor with tunnel ram and Holley 660's
#5 ·
I have a couple of videos of the white & blue one. It is a nice piece of hardware!! The owner is "After You 362"
#9 ·
Engine combos reponse
There is not a motor in the boat now......but it will probably be getting one soon by mid March or earlier I will install a hi compression .100 over 427 .400" long rod 447ci with an .801" solid roller rect 320cc heads tunnel ram and 660s.
I think it'll be a blast with this 13.5 to 1 combo. You can buy it with or without this motor and I'll give you true GPS and video if you were to be buying the boat all set up to run turn key.
The trailer does have Weld Draglite wheels and its tandem axle.
