I am gonna go look at this boat tomorrow and was wondering if anyone had any info on Wreidt. Did they build good boats? I cant find anything on a bubble deck version of their boats.
I looked on your site for more info about a special order tank and didn't see any section with tanks. What tank do you have built and what is ballpark cost? What is the cleaner better way to mount a replacement tank? Thanks.Tanks are still available as "special build/special order" , the tank mounting method always seemed "cheesy" to us but its simply the way it was done on production boats back in the day , there are cleaner better ways available in retrofit
Moving this thread back up in hopes someone who has been there and done that with tank replacement will chime in. TIA.I had a Wreidt Maverick. Fun boat and built well. I now have a Wreidt Stinger that I'm doing a restro on. I replaced the gas tank, not a big deal.
The tank problem is not just Wreidt boats but any boat with fiberglass gas tanks that use e10 gas or any gas with ethanol in it. The ethanol eats the tank from the inside out. The gel coat (or some type of coating) on the inside of the tank, gets destroyed and will gum up the entire fuel system and I hear can ruin a motor. Point being, any fiberglass tank needs to be replaced with plastic or aluminum. Plastic is about half the price of aluminum. I ended up using a plastic thank from Moeller.
PM me if you get the boat and want to know first hand about a DIY tank replacement. You should be able to get money off the boat for the tank deal.
www.moellermarine.com/
Me too. He seemed uninterested in figuring out tanks that would work in such an old boat, or perhaps he doesn't know what tank works in a Wriedt. It's not like Wriedts are that common.Ok very surprised Imco could not help you out.
